- #2
Sorry, it’s a 5800H, not 5850U
It’s a brand new logitech headset with boom mike. The driver and HD audio controller are correctly set and not muted. Not quite sure what the AirPods firmware is needed for. OS is Linux Mint 21.3.
muttley
Hi there
1.Test with a Different Application: You can test the microphone using an application like Audacity or any other recording software to see if it’s detected properly. If the microphone works in some applications but not others, it may be an issue specific to the software.
2.
Update Audio Drivers: While Linux Mint generally has good support for drivers, ensure that your audio drivers are up to date. You can update the system and the drivers using the update manager or terminal commands to ensure everything is working correctly.
3.Please send us a picture of SN number and BIOS version .
So we would be able to know whether it is latest BIOS and send you files accordingly.
Here`s how to check your BIOS version:
or try this
https://mega.nz/#F!yuISGa4I!s1bQQajKwnsEdzjqq4nopQ
Audacity shows the correct RealTek drivers but does not detect the microphone. All drivers are up to date according to Driver Manager.
BIOS version is in my first message:
BIOS version 5800H602
Build date 06/15/2023
Serial number D58003JH4535
BIOS has been successfully updated but that hasn’t solved the microphone issue.
This is a Linux only PC. Mic does work on a separate Windows laptop. No worries, I am going to convert it to USB and see if that helps.
No luck with a USB mic either. All the RealTek drivers are there but no recorded sound.
muttley
Could you pls try to reinstall Linux System?
Here is 23.04 Ubuntu file: https://mega.nz/file/ejhCjRwI#26S86QbI69a5q042yXGx_56wQVMVzAw6O8gEKmigid8
Tutorial: https://mega.nz/file/KmpXSChI#27mlJKjnphFssA3jXc8vYoChbLcxi8eyXVWKSha929s
Best regards!
Yue
Customer Support
