dahjah Well al worked great yesterday, I shutdown a few times restarted a few times throughout the day just making sure all was well, and it was until this morning. This morning the thunderbolt port isn’t working again after shutting down over night.
support1 dahjah Hi there, Please turn off the PC , unplug the power supply and other USB devices, then put the pin in the CMOS pinhole and press it for about 10 seconds , restart the PC after ten minutes. Here is the tutorial https://url.bee-link.cn/5FdW
Joseitogreg The firmware update is done for efi shell opcion no for efi usb device in the boot menu after pulse f7
Twinklekapoor It appears the EFI USB Device option is not appearing. Try to see if the USB drive is properly formatted, that USB boot is turned on in the BIOS, and try resetting or updating the BIOS. Let me know if that works!
yasdum I have gt14i, and get ic 0 active section error 3 IC 0 update error 7. So have can i flash the firmware?
Hankydooodle yasdum I encountered this same error yesterday when I tried to flash. Were you able to get it working or still running into the same issue?
